Old 03-02-2021, 05:53 AM   #3 (permalink)
serialk11r
I just saw the 10% off code on SD and was considering that 16kW PTO generator.
Given the current unrest, I was thinking, ecomodding a generator would be a nice project wouldn't it?
I was thinking you could probably fit a second spark plug, add a little thermal barrier coating, increase the compression ratio, and run lean.
