Old 03-06-2021, 04:38 AM   #1 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Questions about the Nissan Leaf
I'm seeing conflicting information online about the Leaf.
Some Leafs ( Leaves ? ) have a quick charger built in, correct ?
There is a "Charge Point" station around two miles away from me.
Can Leafs use a public quick charge like this ?
I am reading that even with a quick charger, your charge times could take up to 10 hours. That's crazy !
Other EVs can charge in less than 30 minutes, and be on their way.
I would imagine Leaf drivers are absolutely hated at charge stations, because they take so long to charge.
And charge time take even longer as the car ages.
I owned my ICE car for 21 years and spent maybe $700 or 800 total on all tires, batteries, and such.
( I drive very little )
With an EV, you have to replace the battery every few years, regardless.
So as I had asked in another post, this would be like buying a car that has an ICE and transmission that has to be replaced every few years, correct ?
So the cost of ownership in 20 years for the battery alone would be several thousand dollars ?
( Like $20,000 + ? )
My car sat a lot. I don't drive much. My car sits in one spot for two weeks or more at a time.
Do EVs lose charge just sittong there ?
Used Leafs have around 50 miles of range.
So this means even if I just drive short trips to the grocery store and back, I would have to charge the car every other trip I take.
And each time I charge, it would cost more than the mere pennies I use in gas to drive to the nearby store and back.
I would have to rent a car for longer trips.
I take about two per year.
With all of these drawbacks, I still find myself interested in the idea of owning an EV.
It's an impractical desire of mine since I was a teen, and at my age, I see this as perhaps my last car purchase.
My budget is $6,000 or less, and the only EV i see at that cost is a Leaf.
My main reason for wanting a Leaf is the geek factor.
But bottom line - it's a want, and not a need.
( And an expensive one )
