Old 03-10-2021, 05:28 PM   #822 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
The Rabbit cornering and the Fuller static test both show that the rear wheel should trail the outer wheel.
A rabbit lifting it's rear wheel while braking into a corner says nothing about how a trike would react in the same situation.
The real world is more than static tests.
For an idea of what it takes to get a reverse trike up on two wheels.
Moderate speed under acceleration and at 1:00 ...
Or this Slingshot. Smooth pavement and too much speed. A normal car would just spin but once the Slingshot swaps ends - over it goes. (some mild swearing at the end)
There is a cottage industry churning out dual wheel kits for the Slingshot
