Thread: iDuino MPGuino
Old 09-30-2008, 07:51 PM   #99 (permalink)
Spiffed
Originally Posted by Joe_Bloe View Post
Anyone know if this think will fit in an Altoids tin?
If you read the installation page:
http://spiffie.org/kits/mpguino/installation.shtml
It tells you the minimum enclosure dimensions...
You'll need a box atleast 87mm x 37mm x 23mm if you intend to enclose the entire MPGuino. An Altoids tin is 93mm x 58mm x 21 mm. It sounds like it just might work, assuming you're OK with hanging the capacitors and RJ11 connector out the backside or can hang more of the LCD and buttons out the front.
