Old 03-26-2021, 04:20 AM   #17 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
Originally Posted by ksa8907 View Post
In the Volt, a lot of noise comes from the back hatch. I used some door jamb seal strips for that, helped some. I surmised but didn't act, there is likely a lot of wind noise generated from the lip at the leading edge of the hatch.
Install some shag carpet and foam squares on the ceiling!
What I'm hearing is that I should break out the painter's tape and tape over that gap to see what happens.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
