Old 03-27-2021, 08:22 PM   #4 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Even if the battery gets shielded from the excessive cabin heat somehow, it may not be 100% effective once such excessive heat builds up at a higher rate.
From the looks of it, there is a tunnel under the cabin.
It pokes up into the floorboard, but to me, looks as though it is shielded from the cabin heat.
I think it might be a bit too OCD to worry about it.
I guess the real question I should consider, is if an added bellpan would trap heat from the battery.
