Old 03-28-2021, 06:07 PM   #17 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I took a screengrab of the data sheet.
I will try and make some sense of it - but if I can't, can you please give a breakdown of the increases you saw with each aeromod ?
And since I assume the aero horsepower sheet in the Tools section of the forum is for ICE cars, how can we see a spreadsheet for EVs ?
There are a lot of variables, but just as a rough guess, how much of a range increase would you see if you dropped the cD from .28 to .18 on a Volt that has a stock 30 miles of EV range ?
The Volts' frontal area is 23.7
The only aero dirty place I see on the Volt is the underside.
It looks like they hit all the right areas - grille block, extremely flush wheel to fender trasitions, and rear quarter trip strips.
- Yet the car has a poor .281 cD
There is not much else a person could do to improve the car besides the bellypan, and airdam delete, so it seems like a very hard car to modify drag on.
A 10 count reduction in drag is close to impossible, but I'm just curious.
Also, @ conor v : did you ever get around to taking off the front spoiler and adding a bellypan ?
The only thing I can think of that might help besides that is a boattail.
At best, ( an educated guess ) what might that do for the range ?
- Thanks
