You should be able to pick up a G2 Volt for less than 15k unless car prices are way higher in your area
I looked in area code 94122 on Cargurus and there were at least a dozen 2017 and 2018 Volts under 15k
My 2018 G2 Volt gets over 53 miles of EV range out of the box, more if you hypermile (or at least don't drive in sport mode all the time)
The ICE will take it another 350 - 400 miles depending on your driving habits and the G2 uses regular unleaded. The tank is pressurized so you can let the gas sit a long time if necessary
