I’m honestly thinking the same. I may attempt to seal them when the rear wheels come off to do sway bar mounts (issues mounting aftermarket bar), but I’m not in any big hurry to get under there. Next will be a mid belly pan that also shields the fuel tank and shrouds the axle beam and sway bar, but that will have to come after some rust repair and subframe connectors. I wanna stiffen the chassis up and make necessary repairs while I’ve got the grinder and welder out. Should add about 20lb overall that I can cut out from somewhere else less important
My current Ecotec project...
![](http://ecomodder.com/forum/fe-graphs/sig10025a.png)
My last Ecotec project...
