Originally Posted by Isaac Zachary
Ya, some of those points I already knew. I also learned some too, so thanks!
From what I can tell the guy is quite the amateur who exaggerates a lot in an attempt to convince everyone. It does seem like he might be hiding something and trying to cover it over with exaggerations. Or he's just exaggerating to try to convince everyone.
But in the end, I don't see any real advantage of his product unless it had more capacity. If the lithium battery has less of an internal resistance it may soak up and let out more of it's capacity than the NiMH. But he doesn't explain how he knows that for sure.
His product could be sold for 1/3 his current retail
If he would use that advantage...
But he likely wants to make the most out of limited demand
