Old 04-04-2021, 04:29 PM   #11 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Cannot test windows down.Its so cold it will start to heat the cabin and it will ruin results. Should have +20 celsius outside temp and it would give accurate results. Lowest temp request goes is 16 celsius.
Cool report on the wheels and grill shudder. There was measurable difference with grill block in place...
Did more pressure testing. Test was correct yesterday(it was sunny today cloudy so tarmac colder today which is seen in results). Testing method is still accurate and valid the optimum pressure is between 2,4-2,6 bar. In the end did two runs with 2,3 bar and results were 0,24% difference to each other ( in the end of measurements there started to be more wind (tuulta) In EV you hear it clearly. Consumption starts to go higher after under 2,4 bar and over 2,6 bar.
There is noticeable difference in grip with low 2,4 bar pressures the slip ligth is not coming on in dry tarmac but with 3,5 bar is on up to 100km/h speeds.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
Joggernot (04-05-2021)
