Old 10-01-2008, 01:57 PM   #20 (permalink)
mavinwy
Neon1 - '97 Plymouth Neon highline
90 day: 27.26 mpg (US)
Actually, the GM 3.8 is the Buick 231. Same motor.
They came carburated, so the swap would be relatively easy. There is also a large aftermarket for them.
Retro-fitting a dodge engine would likely be problematic, but of course...anything is possible if you throw enough money at it, but I don't think changing to another manufacturers engine would pay for itself.
Chenging engines is also generally easier on a RWD car, even if you have to change the motor and trasmission, a custom driveshaft can be built to mate up to the rear end.
Jim
