Old 04-10-2021, 09:51 AM   #4 (permalink)
Piotrsko
Thinking about it some more: the C6 has a bolt on case extender that you remove for adding the borgwarner. That should have the shaft you want in the proper configuration. Find a 4wd option truck that is 2wd at pick a part, it's like 3bolts to remove and pukes tranny fluid.
