Old 04-10-2021, 02:53 PM   #5 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Thought the hex might be meant to hold bits, but now that I see it on a big screen, it looks like it has a key on one side.
Not sure it's much help, but mine looks nothing like that inside:
The screw is a left-hand thread and a much larger diameter than that tiny hole at the bottom of yours:
Model # of mine:
My older one is the same:
Think mine is taper-fit, so it needs the screw. Yours looks like a pressed-on hex with a key, which doesn't necessarily require any kind of screw. If you can find one that fits and a washer, you can use it to press it back in...if not, well, not sure if hitting it with a hammer hard enough to get it back on wouldn't break things inside.
ID:	30410   Click image for larger version
ID:	30411   Click image for larger version
ID:	30412   Click image for larger version
