Old 04-11-2021, 10:34 PM   #1 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 43.95 mpg (US)
Tire size vs MPG - EPA test results
The new different trim levels of the new Honda Accord Hybrid come with different tire sizes, and different EPA gas mileage results. The lower trim levels have 225/50 tires on 17 inch wheels, and get 48 EPA MPG. The higher trim levels have 235/40 tires on 19 inch wheels and get 44 EPA MPG.
The wider tires are 0.5" larger diameter, or 2%. The 2% diameter difference does not explain the 9% MPG difference. And 10 mm width difference should not cause enough increased air drag to cause the 9% MPG difference. I suspect that the narrower tires are LRR, and the wider tires are not.
Article: https://arstechnica.com/cars/2021/04...accord-hybrid/
The Following User Says Thank You to JRMichler For This Useful Post:
Joggernot (04-12-2021)
