Old 04-12-2021, 08:44 PM   #3 (permalink)
TURBO-DIESEL-FREAK
TURBO-DIESEL-FREAK's Avatar
I guess you already know the current VM Motori engine is still basically an updated version of the OHV ones, which by the way are still manufactured for stationary/industrial and marine applications. So, I suppose it might not be rocket-science to expand the suitability of your device to the newer engines.
The science and the engineering is all the same, but it is still difficult and expensive to get a new serviceable thermostat developed that will use a suitable and commonly available thermostat valve...... If the housing and/or the location on the engine has changed, a whole new CNC Machining program needs to be developed.
