Old 04-12-2021, 09:51 PM   #33 (permalink)
cRiPpLe_rOoStEr
CR: nowhere you indicated it was a normally aspirated diesel but I assumed by 1600 cc you were saying pancake aircooled.
I thought the D on 1.6D gave a clue of what I was refering to.
But I have seen fuel injectors drilled and tapped into the main fuel plenum
That's what I usually see on CNG conversions anyway. But converting a Diesel engine to dedicated-CNG is uncommon here, even though I remember seeing trucks fitted with a dual-fuel setup allowing them to use simultaneously Diesel fuel and CNG. IIRC there were some conversions from Diesel to dedicated-CNG in Argentina, but even the Argentinian vehicles running on CNG were based on an originally spark-ignited gasser.
