Old 04-13-2021, 01:13 AM   #37 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
I doubt I could find a reference* but back in the day Rod & Custom magazine had an explanation that hinged on the line between the front and rear roll centers. If the line slope one way or the other you get under- or over-steer, if the line is level it's neutral.
Is that what Grand Turismo said?
*Roll Center Explained - FMI Knowledge Base
I haven't quiet gotten through the whole thing. But I didn't see that about suspension, although it does mention suspension's play in handling. It even mentions the disadvantages of swing axel suspension on rear engine cars over newer suspension designs on rear engine cars.
But it talks mostly about weight placement. It has a section on each drive type:
Front engine/front wheel drive "FF"
Front engine/rear wheel drive "FR"
Mid-engine/rear wheel drive "MR"
Rear engine/rear wheel drive "RR"
And Four-wheel drive, which it calls "FWD".
It also has many other sections from acceleration to breaking to corner entering and corner exiting. You know, the stuff you'd need to know to play a race simulation game.
