Old 04-13-2021, 03:27 PM   #42 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Packaging / manufacturing cost.
It is much easier to package a liquid-cooled engine and transaxle in the front of the car. You put the radiator up front and coolant lines are short. Same with the hoses between the engine and heater core. Throttle cables are easy to route. Shifter linkages are shorter and less complicated.
As a manufacturer I can also make a sedan, coupe, wagon, and hatchback variation and not have to touch the front half of the car.
Then there is luggage / cargo room. With a rear engine car you basically just have the frunk. With a front engine car it is easy to fold down the rear seat to double the cargo room.
Does this mean that economy EV's Will continue to be Front Wheel Drive since you'd need longer cooling hoses or will it not matter as much since the cooling hoses will probably be much smaller? I guess we'll find out.
