Old 04-16-2021, 10:24 AM   #8 (permalink)
Autobahnschleicher
Aerospyder - '00 Toyota MR2 Spyder
90 day: 41.98 mpg (US)
Simme - '83 IFA Simson Suhl S51
Motorcycle
90 day: 76.59 mpg (US)
My rear tires are both wearing evenly and at an expected rate, keep in mind they have to take more load than the front tires and the car is RWD.
There are only about 400 kg on the front axle and the brake ballance of my car is nowhere near as front heavy as it is in FR or FF cars, so even when braking the tiires aren't loaded as hard as they are in many FF cars, leading to rather low wear on the front axle.
Got an alignment to factory spec after doing the shocks, the car has rather low negative camber and next to no toe on the front and rear axle.
I'm running 280TW tires, wich means they last about half as long as regular economy tires with their 500-600TW ratings.
But I'll measure the exact tread depth later to seeexactly how much I've worn them down.
The Following User Says Thank You to Autobahnschleicher For This Useful Post:
Ecky (04-22-2021)
