Old 04-18-2021, 01:16 AM   #161 (permalink)
ps2fixer
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
Surprisingly, some econoboxes which cater to countries where they're often the only car of the household are surprisingly more comfortable than their size may suggest.
Yea, the thing has storage compartments everywhere, it feels more roomy and everything than the corolla. The body style isn't my first pick, but I'm more about function than looks, I just don't like drawing too much attention (boat tails and such). The echo I have has a vin starting with JT, so it's built in japan and came over on a ship. The era of Corolla's I like (96-97) are all or almost all US built with 4T starting VIN. Sadly the echo seems to be a bit lower build quality in some areas (door pins for example), but in other areas it seems better. Like it has rust, but not everything is rust. The Corolla I was driving has rust basically everywhere. It has some rig ups I need to fix, I don't like day time running lights (atleast give me control if I want them on auto or not) so I'll probably be disabling that in time even though it seems to work well, not a battery killer like some other brands.
@serialk11r
That's a lot of info you dropped on me xD. The corolla's I worked with are 4A/7A engines. I do have a corolla with a stick trans in it too with a bad engine. It almost sounds like there's a fair chance the trans wouldn't be too hard to be a backup for the Echo. No clue about spline counts and such, I suspect the mounts are similar or not hard to make something up.
Some looking around suggests the engine is a 1NZ-FE, atleast from one wiki page, when I searched before I had a different engine come up. I didn't check the emissions sticker to validate. Sounds like it should be pretty similar engine pattern for the 4A/7A transmissions then. Reading a bit about the 1NZ-FE, I guess it's based on the 1NZ-FXE which is a lower power output, but high compression mechanically, but valve timing is simulated to 9.5:1 ratio type of engine. I heard those can be very efficient. Wiki claims the peak thermal efficiency is around 37%. Another google search says typical diesels peak at around 42%, so that's quite impressive. It almost makes me want to find one of those engines and do an engine swap lol. ~75hp vs 108hp wouldn't be the end of the world or anything. 25% or so lower power, but say 20% better mpg under the same conditions could be worth it.
Also the 1ZZ/2ZZ engines I've avoided a bit, I've read they don't last as long as the older 4A/7A engines. I got to ride in one once and it seemed to have a nice power increase for it's size. The newer Corolla's with them seem to also be lower quality, the cheaper ones are in generally a lot worse shape than a similar priced older one.
Anyway, I have two gas/fuel suckers, and one that should basically go forever on gas. I guess I have a legit car that matches up to the logic of an ecomodder member again xD.
