Old 04-18-2021, 09:17 PM   #162 (permalink)
cRiPpLe_rOoStEr
Originally Posted by ps2fixer View Post
The corolla's I worked with are 4A/7A engines. I do have a corolla with a stick trans in it too with a bad engine. It almost sounds like there's a fair chance the trans wouldn't be too hard to be a backup for the Echo. No clue about spline counts and such, I suspect the mounts are similar or not hard to make something up.
Gotta have to check if the bolt pattern is the same between the Japanese ones, which were fitted with the 1NZ-FE, and the Chinese ones which were fitted with some A-series engines.
Reading a bit about the 1NZ-FE, I guess it's based on the 1NZ-FXE which is a lower power output, but high compression mechanically, but valve timing is simulated to 9.5:1 ratio type of engine. I heard those can be very efficient. Wiki claims the peak thermal efficiency is around 37%. Another google search says typical diesels peak at around 42%, so that's quite impressive. It almost makes me want to find one of those engines and do an engine swap lol. ~75hp vs 108hp wouldn't be the end of the world or anything. 25% or so lower power, but say 20% better mpg under the same conditions could be worth it.
Don't forget the 1NZ-FXE was meant for hybrids, and it also had a lower torque output (slightly over 20% lower).
