Originally Posted by JulianEdgar
The ICE car that I have data on with the second-lowest cooling drag proportion is also a very powerful car; whereas the data I have on the car with the lowest cooling drag proportion is a very low power car.
Yes, but that's kind of cheating as it uses its cooling system exaust as air curtains for the front wheels.
So more depends on car design than engine power.
Partialy correct, cooling system design indeed makes a major difference in drag.
However for a given type of design, drag increases with airflow demand.
And you can only realisticly feed two air curtains, there is only so much air they need.
If it was a little smaller, it might even have net negative drag.
This is also why people saying that my use of the Tesla Model S and Taycan for high proportional cooling drag in BEVs is no good, because they're powerful cars, are missing a key point.)
The Model S also has issues because of its undersized cooling system while the Taycan does not.
And the Taycan carries a drag penalty for it, making it a known "electron guzzler", but it can make up for it in higher cruising and charge speed.
