Old 04-21-2021, 12:01 PM   #164 (permalink)
aerohead
only
Originally Posted by JulianEdgar View Post
Yes. I am the only person here who has quoted citations from the technical literature that shows percentage cooling drag of BEVs (ie percentage of total aerodynamic drag).
You’ve posted a wide range of irrelevant material, your own theories, and various amounts of typical Aerohead misinformation.
So, situation as normal for your contributions.
I'm ecstatic that uni-dimensional thinking-like posts are, so far, limited to a single member.
And to be fair, I'll attribute the shortcoming to undereducation.
Without immersion in mechanical engineering, you'll remain, sequestered within a one-dimensional universe.
If you'll keep re-reading Dr. Wolf, some patterns may begin to emerge which will provide the needed contrast, necessary to understand the most fundamental underlying functions of a cooling system.
Otherwise, it doesn't matter how many examples from the 'technical literature' you table. They are contextual. Any pretense that they can stand as reported is pure pedantry. SNAFU.
