Old 04-22-2021, 12:49 PM   #5 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
What kind of connectors does it use? 250 kW isn't much for a truck-sized battery.
CCS. The blue connector has two CCS plugs paired side by side.
I see a substation of sorts was required to supply that enormous capacity. What percent of utilization is required to break even on the fixed and variable costs? I think I read somewhere that DCFC typically requires 1/3rd utilization, meaning 8hrs of billable charging per day to break even.
I doubt either party is looking to make money on this first station. Press statement:
"The site is built to immediately provide charging for EVs of all shapes and sizes, and will serve as an innovation center, allowing both PGE and DTNA to study energy management, charger use and performance, and, in the case of DTNA, its own vehicles’ charging performance."
Big trucks only I hope? Some eedjut in a tesla parked for a 1/2 hour not charging would be annoying more that it already is.
Open to anyone and any vehicle with a CCS plug. The article does say some of the 8 chargers will be reserved for Daimler.
Originally Posted by Autobahnschleicher View Post
I'm surprised it's only 250 kW.
Ionity has mostly 350 kW chargers with Type-2 CCS for cars here.
Different articles have different numbers. Some say 150 kW, some 250 kW, and some say 350 kW.
Unless something has changed from earlier press releases they are 150 kW with the dual plugs capable of charging at 300 kW.
The Following User Says Thank You to JSH For This Useful Post:
redpoint5 (04-22-2021)
