Thread: Decimal places
Old 04-23-2021, 12:10 PM   #26 (permalink)
AeroMcAeroFace
Long time lurker
AeroMcAeroFace's Avatar
Probably depends upon the type of science one is doing.
When I'm 'noodling', I simply leave whatever is on the display, or move it into memory, for future re-insertion, for the duration of the calculations.
It would be 'more' work, and less time-efficient to do otherwise. Not to mention accuracy issues.
When I began formal studies, rolling force coefficients for tires easily ran to ten decimal places. Observed wind tunnel values, up to 4-places.
If you're looking for that 0.005 difference from a radiator shutter, you want as 'tight' an accounting as possible.
You know that it requires extremely advanced statistical analysis tools to even identify some 'trends' which are under scientific examination?
I have no doubt that the measured value in the wind tunnel was to 4 or even 5 decimal places. However, the published number was to two decimal places.
Agreed, on the tiny change from a radiator shutter, they will do measurements down to 3,4 or 5 decimal places. However, that doesn't necessarily reflect in the published data, if the cD was actually 0.304 and then a radiator shutter was added that reduced the drag to an actual 0.299, the published number is still going to be 0.30.
The difference may be 1.6%, but it would be erroneous to claim that because the initial figure was 0.30 and there is a 1.6% reduction, that the new drag coefficient is 0.295.
Because as we see in the above example the actual figure is 0.299.
What you should have said is that actually the number observed could be between these two points, which would be odd unless the sensors were not calibrated to a standard.
You are confusing accuracy of measurements with precision, read about it here https://en.wikipedia.org/wiki/Accuracy_and_precision.
The Following 2 Users Say Thank You to AeroMcAeroFace For This Useful Post:
aerohead (04-23-2021), freebeard (04-23-2021)
