Old 04-23-2021, 06:36 PM   #48 (permalink)
JulianEdgar
Originally Posted by Vekke View Post
https://publications.lib.chalmers.se...512/250512.pdf
Here is a cfd study on spats. lower is better for wheel drag but whole car drag starts to rise after 40mm flap heigth in this test. I measured roughly the ground clearance in that model is 150mm and tire width 210mm (205 or 215). They tested only flat spats. That 40mm flap leaves 110mm ground clearance and that 60mm flap leaves 90mm ground clearance.
Max savings in that cdf study just on front flaps was 5,5% on drag. I believe that is easily measurable on road.
If you are able to get those lower flaps working that lower wheel drag 18,8%, without increasing too much body drag more is possible than that 5,5%. And this was just for front spats. So different shapes and sizes will give different results.
You seemed to have moved the goal posts. My comment that measuring a drag change on the road would be difficult related to what you said you were going to do - use shaped deflectors instead of flat deflectors.
