Old 04-24-2021, 12:46 AM   #41 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
“disingenuous”
Really...???
Using your Co2 numbers
China 1,397,897,720 people x 8 = 11,183,181,760 tons Co2 and increasing
India 1,339,330,514 people x 1.9 = 2,544,727,976.6 tons Co2 and stable (maybe)
USA 330,425,184 people x 16.1 = 5,319,845,462.4 tons Co2 and contracting
The USA is retiring coal plants.
China is building them.
Yes, it is disingenuous so start counting carbon emissions now and ignore 100 years of massive carbon use by rich countries. Carbon built-up in the atmosphere is cumulative.
Yes, it is disingenuous to tell people that are using 1/2 the carbon that you are using the you will not commit to carbon reduction unless they do the same.
Did you read this article? It is a really good one.
1. Yes, China built a huge amount of coal power plants during the 12th 5 year plan. They were make-work projects. Even as China continues to add coal fired power plants their utilization of that generating capacity is falling - down to 49% in 2019. China built a lot of power plants and is building more but is using less than 1/2 of the installed capacity.
2. Power plants only burn 54% of the coal consumed in China. China still uses a huge amount of coal in very inefficient ways. People heating their houses and cooking their food on coal stoves. Apartment buildings and businesses have inefficient and polluting coal boilers.
China has a goal to electrify heating and cooking. To replaced thousands of individual coal stoves with one power plant that burns coal much more efficiently and cleanly.
You can actually build coal power plants and reduce emissions at the same time if that power plant is replacing coal burned by individual households and businesses.
From the article:
One driver of higher capacity targets is the expected electrification of building heat and industrial energy needs, which are often currently supplied by highly polluting small-scale coal-burning. This point has been emphasised by the chief director of the National Energy Administration (NEA).
Replacing direct coal use with gas and electricity has been an important pattern in recent years, in part due to efforts to tackle local air pollution. Energy security concerns are likely to mean further emphasis on electricity rather than gas as the substitute.
