Old 04-27-2021, 04:31 AM   #20 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Few more pictures of the car found. The air suspension makes it difficult to estimate things, but we know the wheelbase of the car which is 3210mm.
With that data you can calculate that the wheel diameter is around 760mm that could then be 255/55R19-->763mm.
After this you can measure ground clearance under the car to be around 140mm at least in the picture I looked.
You can also measure the heigths of the tire flaps. In front they are around 45mm height and lowest point is at 100mm. Accuracy of measurement is +-5mm
at rear the flaps are little smaller. Heigth of the flap is 25mm. Accuracy of those measurements I would say is +-7mm more towards the plus side as there is no clear pictures of the flaps alone with wheel specially from rear.
Now remember the car has air suspension and lowers itself at higher speeds so flaps will come even closer to ground.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 2 Users Say Thank You to Vekke For This Useful Post:
aerohead (12-27-2021), MetroMPG (04-27-2021)
