Old 04-27-2021, 07:48 PM   #12 (permalink)
redpoint5
90 day: 29.78 mpg (US)
They say the level two charger drops that to just 2.5 hours. Makes me think the factory box is just pretty amp limited. It says 12 amps 1440 watts that's at 120. So if i tried to use the factory box but with a 240 adaptor would it just run the same 12 amps but then 2880 watts? That means an actual 240 charger running the full 27.5 amps is needed to do the 6600 watts.
anyway even at 1440 watts a 16,000 watt battery should fully charge in 11.1 hours but I'm sure it ramps down a couple times as it approaches 100%
I bet the 2.5 hrs at 6.6 is a bit optimistic as well, probably more like 3 to hit 100%.
Also isn't 100% charging bad? I can't seem it set other limits. Maybe what they call 100% isn't actually 100%.
Your assumptions are correct.
Note that preheating a plug-in (or EV) usually draws more than the 120v outlet can keep up with, so it will use a little bit of the battery in the process. Generally you need to step up to L2 if you want to avoid any battery drain during preheating.
The Following 3 Users Say Thank You to redpoint5 For This Useful Post:
Hersbird (04-27-2021), samwichse (04-28-2021), Xist (05-17-2021)
