Originally Posted by aerohead
I'm sure. Until you're sure, you need to keep thinking about it. Until it clicks.
Well, since no one else has commented, I guess the light bulb hasn't gone on for anyone else either.
In your normal overly complex manner, you're simply stating what is obvious to anyone know knows anything at all about cars:
- The air con condenser causes aero drag.
- The air con condenser needs to be cooled.
- The air con system has to work when it is hot outside.
- An air con condenser fan uses electrical power.
I guess it's only some kind of breakthrough if you'd never considered these aspects before.
