Old 04-29-2021, 09:28 PM   #6 (permalink)
cRiPpLe_rOoStEr
I'm quite familiar with ethanol as a motor fuel. Running lean might not be so bad it you're willing to avoid much changes to the engine itself, considering ethanol already cools the intake air stream further than gasoline. On the other hand, it may not increase performance to the same extent a more usual and higher AFR would do.
