Originally Posted by AeroMcAeroFace
Attachment 30594
Has anyone solved the wheel arch/cavity issue? You can't put a panel there because the wheel couldn't turn, but it creates a lot of turbulence
Looks like a job for an air-curtain ?
EDIT:
Found this image researching the idea.
Porsche Panamera extra-large lightweight underfloor cover for improved aerodynamics
https://www.motor1.com/photo/319669/...-aerodynamics/
For the above to work, the underbelly wheel opening is an inlet for the wheel that acts like a fan which in turn changes the direction of the air 90 degrees for yet another air curtain over the outside face of the wheel.
Certainly more complex than the idea I had in mind which is to add a convergent duct in the front chin apron and jet it at the belly pan plane just prior to the opening.
