Old 05-01-2021, 01:55 AM   #171 (permalink)
ps2fixer
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
I'll have to get pics, the whole frame for the engine/suspention needs rebuilt/replaced besides the rear end issues, and the existing problems I already knew about. It's basically spend $1000+ into this car, or one in pretty good shape runs like $1500. Generally I don't mind throwing a bit of money at a beater, but I think this one is being a bit too much of a money pit (first toyota that I ran across that is like this).
I'd atleast like to find another car that has a bit more integrity to start with for cheap, say with a bad engine, or something like that. I also have a couple older 92-96 era camry bodies around, those things basically don't rust. They are pretty heavy cars though, don't think the 1.5L would do too well in a ~3000lb car when the orig car is ~2000lbs, of course more frontal area too. Only like 108hp vs 130ish, so not a crazy amount less. I still have the corolla too, it's a bit easier to fix than the echo, just some square tubing and nuts welded in to bolt the gas tank straps to and it should be good to go for a couple years or so. It did sit a while, so not sure if there's any issues from sitting (brakes, lines, mice issues, etc).
