Old 05-02-2021, 12:04 PM   #15 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
I once had a 1972 air-cooled VW Super Beetle that I increased the compression ratio from 7.3:1 to 10:1 and ran it lean, around 16:1AFR (I'm not sure what that equates to lambda since I just went by an AFR gauge. The car ran que well.
One big thing that was necessary was to tweak the ignition. Lean burn needs more advance. So yes, I had an air-cooled car with a high compression ratio running lean and had an ignition timing that was quite a bit advanced more than stock mainly driving up and down steep mountain passes. I didn't run any ethanol in the car though. But I did average 30mpg.
I would think if you have sudden changes in acceleration it's due to ignition timing.
