Old 05-06-2021, 09:52 PM   #32 (permalink)
serialk11r
I found the software's soft limit to be ~1.2 lambda. I can "trick" it into allowing me to flash a much leaner tune, but if I save and reopen my calibration in software, it resets back down to 1.2 lambda.
What software are you using? You can probably take the raw binary and jack up the values there. If it lets you go to 1.2, it probably will go higher. (as opposed to e.g. an early Bosch ECU, where it's encoded in 8 bit and 127 = stoich)
