Old 05-08-2021, 09:47 AM   #7 (permalink)
Piotrsko
Could you not work backwards starting with how much drag would be required to lift said cow and pick an arbitrary wind speed? Said cow should not fall out of the sky as it rotates its frontal location, or would it?
There, you've done it, my mind is sussing out all versions of cow rotation in flight including leg retraction while inverted. I hope you're happy.
aerohead (05-12-2021)
