Old 05-08-2021, 10:23 AM   #14 (permalink)
EcoCivic
Of course it's going to sag. Motors have huge starting currents relative to running current. All inductors exhibit the same characteristic including the A/C clutch. Look at the current after the fan is up to speed.
You're right. But my thought was since the fans should have already been spinning from the wind blowing through them, there shouldn't have been much of a drop on startup. The AC compressor clutch may be the same way, but it only draws a couple of amps instead of 20+ amps and there is no noticeable voltage drop when it comes on as long as the fans are off.
