Originally Posted by Juho
The ignition timing maps do look quite different than with the catalytic converter headers.
Quite a lot less advance required for the ~same fuel consumption.
Yea that's expected, the residual exhaust gas fraction is reduced with different headers. +10% EGR is on the order of +5 degrees of timing, so seeing several degrees of change at low load is completely normal.
