Originally Posted by aerohead
A thought experiment, because it's safe, would be to draft a semitrailer at very close range on an isolated test course, at your chosen velocity, and see whether or not the engine could reach anywhere close to your target mileage.
If that didn't do it, nothing would. A Go NoGo.
according to the meter the Best MPG zone is at 45mph which runs the engine at 1050-1070 RPM in v8 mode... it will show a consistent 40mpg on the display.meter..with the A/C on ( no change if the A/C is off ) the issue is wasting a ton getting up to speed..
it's really hard to keep it in that gear If I was able to keep it in that gear longer i would net better mpg so it seems like even slight changes would have a huge benefit.... also i noticed the hood flaps around in the wind this could potentially effect the aerodynamics
