I just noticed today that I hadn't re-installed the underbody plastics of the car.
So there might be some gains with the next tank of gas.
Just installed the front one and will install the two rear ones later.
Rain kind of interrupted the whole operation.
Also noticed that installing a flat undertray under my car will likely be an easy job as I have loads of good monting points and for the most part no exaust system in the way.
Only in the rear end where I could make a smooth transition to the stock plastics.
However unlike most aeromods here, this will need to hold strong at speeds well over 200 km/h.
Likely 230-250 km/h depending on how effective it will be.
Due to the higher maximum loads, I will need to use 3 mm ABS-sheets instead of the popular coroplast and reinforce it a lot.
