Old 05-15-2021, 01:29 AM   #25 (permalink)
ssullivan
Jetta - '01 Volkswagen Jetta TDI
Originally Posted by COcyclist View Post
My buddy did this to his TDI and his biggest complaint is how long it takes to get heat into the cabin. .
I could see that on a stock tune, with after TDC injection.
This one got a DIY EGR delete, cutting and welding factory parts. Also tuned for more SOI, this seems to have helped the warmup, I noticed only a slightly longer warmup time after this.
Edit: I should add that it did need a clean of the VNT recently. I attribute this to the combination of a tune with stock SOI table, EGR physically disabled (which wants more SOI), lots of driving, and I guess different fuel chemistry. Hoping the car is good for a while, I actually took some out of the low rpm of the torque limiter, having injectors and hearing loud, deep roar at 1200rpm and wot.
Anyways, more stories about <2000rpm shifting? There is a lot of good evidence here already to suggest it is fine. I do believe the PD engines have stronger bottom ends that would be less prone to lugging-related failures.
