Old 05-16-2021, 11:30 PM   #5 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
At this higher altitude you can advance it a few degrees and not get ping. Warm up the engine and then take it up a steep grade on a hot, high barometric pressure, dry day and floor it. Pull over every once in a while and advance it a degree or two. Don't forget to go over a range of RPMs with it floored. As soon as you hear that rattling marbles in a can sound immediately pull over and retard the timing a couple degrees. From there you should be good as long as you don't get that sound again.
A small amount of ping shouldn't hurt the engine. But it should be stopped immediately. When I advanced my car I didn't realize I had advanced it too far and was pinging upountain passes for years. I thought it was a loose piece of fender. I even drove it like that clear down to Puerto Vallarta and back over several steep roads down there at temperatures over 105⁰ at sea level and didn't ever have any engine problems. Not that I would recommend doing that, but I did get great fuel mileage. It was around 45mpg on the highway when I would measure it.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
Learning (05-17-2021)
