Old 05-20-2021, 11:24 AM   #38 (permalink)
Piotrsko
Worst thing you'll do is cause a leak and then the low pressure shutoff (which works REALLY well) shuts down the A/C to prevent system damage from lack of lubricant.
If this occurs often then I suggest a different operational mode: system default is on, manual override to turn off, can be done with a cheap $5 car relay set up to latch open
EcoCivic (05-20-2021)
