Old 05-21-2021, 09:58 AM   #4 (permalink)
Piotrsko
Even with the biggest massive battery I can conceive, you're looking at most 1,000 lbs including the holding structure. My volt battery is 88 lbs of battery and 300 ish pounds of holder.
I see a lot of yahoos in my 'hood putting 2000 pounds of construction materials into their Toyota pickups. You can tell they are that heavy because the tires in the back partially disappear, and I know what a pallet of concrete block weighs. Moving the battery around is going to solve that?
