Old 05-21-2021, 10:06 AM   #3 (permalink)
Piotrsko
Yes depending on how long it takes to reach thermostat opening and peak engine efficiency. If it's up to temp at the start, the low temp enrichments are off. My F250 in the winter has no defrost heat for 4 miles because it's trying to warm 8 gallons of coolant with reduced btu fuel and it barely generates enough heat at idle to dewax the fuel
