Old 05-21-2021, 01:45 PM   #6 (permalink)
j-c-c
This sounds like an application for one of my new favorite things the planetary screw. duckduckgo.com/?q=planetary+screw
Load balancing would not require fast reaction. Countering corner forces would.
Maybe I wasn't clear enough, my idea was to initially improve load balancing, with a 50/50 weight bias being the ultimate goal. I was thinking if the idea took hold, then the battery might become more of a solution to improve handling/cornering by more active movement, but regardless, a 50/50 weight bias loaded to unloaded, is nearly always ideal in every situation, and I thought worthy, but mainly thinking PU and thier loads. I personally don't see it a complex effort for requiring flexible wiring/coolant lines, ie we have had 4 wheel hydraulic brakes for many decades reliably.
Thanks for the reasoned replies.
