Old 05-21-2021, 01:32 PM   #7 (permalink)
j-c-c
Even with the biggest massive battery I can conceive, you're looking at most 1,000 lbs including the holding structure. My volt battery is 88 lbs of battery and 300 ish pounds of holder.
My ignorance makes it hard to understand the reasoning behind the above numbers. Is the battery encased in a 2" thick Ti tub or something, or is this just unique to a Volt for some reason?
