Old 05-28-2021, 11:24 PM   #23 (permalink)
cRiPpLe_rOoStEr
It is compressor stage heated air that is bypassed from the front of the engine ran down a flex duct in the wing into the cabin then back out to atmosphere through a pressure valve.
Would be quite harder to bleed enough air from a turbocharger fitted to a conventional reciprocating engine. On a sidenote, the ACM also resorts to a turbocompressor and a heat exchanger which resembles an intercooler.
