Old 05-30-2021, 09:29 AM   #67 (permalink)
kach22i
Originally Posted by AeroMcAeroFace View Post
Partial lift has been employed by solar cars, but these cars had high front lift and low rear lift in a straight line and low front lift and high rear lift in a cross -wind. The aerodynamic and form priorities of a solar car would not easily align with the aerodynamic and form priorities of a partially lifting body car.
...........Do I think that this concept is practically applicable? Given the right conditions, priorities and restrictions yes I do. Do I think that those will ever arise? No, I don't.
It was a good question because it forces us to think and challenge dormant assumptions that lay hidden in our minds.
*At Bonneville...............
* You could win, you could lose.
One thing I learned going from scaled model experiments to full scale experiments is that the time, money and consequences also get scaled up.
Yea, I'd imagine that losing at Bonneville isn't a pleasant experience should one survive.
Originally Posted by JulianEdgar View Post
One reason that lift causes increases drag is that more of the tyres are exposed.
Cars with high lift have both increasing Cd with speed and increasing CdA.
I don't think that has been mentioned in this thread.
Good point, not to mention the suspension is designed around certain sprung and unsprung weights that once altered could lead to mishap.
In another thread sometime ago someone mentioned the tires actually grow a bit in height as the rotational momentum stretches out the sidewalls at high revolutions. Kind of like dragster slicks that start out partially flattened and become doughnut like once the green light flashes.
Also in another recent thread someone mentioned the suspension at speed may be forced downward or upward depending on lift and or down-force, which in turn affects the CdA.
FREEBEARD, the doughnut shaped things you mention are 2 foot and not 4 foot and called tires?
You lost me buddy, please clarify for those that just woke up and the coffee hasn't kicked in yet.
aerohead (06-02-2021), AeroMcAeroFace (05-30-2021)
